Leaky shed roof
brianhr
13 Nov 2007
The recent bad weather has found weaknesses in my shed roof. It is only 10ft x 12ft so the work required is small. I have covered it with a tarpaulin for the time-being and have replaced the soggy timbers at the gable ends.
My question relates to the replacement felt. The existing felt is loose-laid (one layer of a fairly heavy felt) and so is easy to remove. Conventional instructions advise not nailing the felt down from the roll but to open it up and let it 'mature' on site. Is this really essential? Could I fix it at the top of the ridge and let it mature under the tarpaulin before finally nailing it down in the spring? The overlaps would be left unsealed.
Hi Brian,
Ive never matured felt,i normally try and wait for a mild,minimal wind day but a warm day is easier for folding it round edges etc.
You could lay it under the tarp and finish it in the spring even just for some better weather.
Regards
Joe
Damn, beat me to it! This a much better solution for shed rooves....much better. Simple, cheap, relatively long-lasting compared with felt, looks better, easier to fit than felt etc etc.......
Most Builder's Merchants have their own brands.
Mike
I have seen really thick bitumen paint that is supposed to fill in cracks and holes in existing felt.
No experience of using it though, but I think I'd try that myself before changing the whole roof...
It isn't a question of changing your whole roof, Pete. If you have to replace the felt because it has given up then this simply nails in place over the top. Much better a job than slopping a liquid about hoping it fills all the gaps!
Mike
PS Onduline is another common brand-name.
With the corrugated sheets, depending on your roof construction, it is also very easy to add a bit of extra light by using an odd clear corrugated panel.
Andy
Many thanks for the suggestions. How did I know Mike would suggest corrugated roof sheets? Actually I have already bought the felt and think the corrugated sheets would look a little too "agricultural" as the shed I inherited is only 18inches from the boundary and rises above the adjoining fence by about 3ft. In fact the shed is only 15ft from my neighbour's back door. I need to be the quietest woodworker around!
I've never actually liked that rolling eyes smiley, but........ :roll:
Mike
Mike, Forget the rolling eyes. Advice is just that, nothing more. I asked about the problems with laying felt at this time of the year. That's all.
So I have a leaky roof on my 'lean-to' garden shed.
I can see how I fix this stuff over the top, on a framework, and I know how to seal the drip edge and the sides. But how do I seal the front edge, to prevent water running down underneath?
Looks to be suitable only for ridge-roofing. Presumably there is a ridge moulding available.
John :)
John :)
By "this stuff" I assume you mean Onduline (or equivalent)? There is a ridge, and there are gable-end pieces as well. I don't follow "seal the front edge".....do you mean the eaves (where it runs into a gutter)?.........or is it that you have a mono-pitch roof, and are referring to the highest point (still called a ridge, I believe)?
Mike
Yes Mike..
There's only one pitch or slope; which has nothing to do with 'planes'!
:) :roll:
I call it a lean-to construction, (although it's a free standing shed) and the front-ridge or head is the bit I am thinking of.
The reason I ask is that I was thinking of putting some kind of corrugated plastic on the top, but I would have had the same problem. This rigid felt sounds ideal!
Thanks for jogging my grey cells on terminology...
Regards
dedee":3inymiqq said:
full fixing instructions for onduline or equivalents here
http://www.slecladding.co.uk/ondulfix.htm
edit,
One tip I would give is try to find roofing screws rather than nails just in case you need to take a sheet up for repair.
Andy
I was ahead of you there Dedee. I had already thought about using an ordinary screwdriver rather than a Birmingham one!
J.
I have been following this post with interest as I had the same problem earlier in the year and I thought solved it. Went down the bituminised corrugated sheet road.
Guess what?
Went into the workshop yesterday to the sound of dripping water.
oh dear it never rains it just pours down. :(
We had 90mm of rain in Devon over the past 7day, and it was heavy, I expect the rain overflowed the corrugations and crept in that way?
Through the holes made for holding sheets down?
