OM99
Custard, thanks for the thread really lovely slab of wood too.
You make it look very easy
Oli
Oli
Wizard9999":3rfceg93 said:If I understand the sequence of events correctly components are machined, joint positions marked up and then domino mortices are cut. You then mention cleaning off the pencil marks, etc. either by planing, sanding or both. I guess this is the point at which your 0.5mm allowance comes in? Having gone to such an effort to ensure the perfect alignment of the components with your shimming, etc. how do you deal with the risk that the planing / sanding doesn't introduce inaccuracy?
SteveF":125rhqjd said:does it's weight make it hard as well?
just wondering wether the 2 come hand in hand
also interested how you "clean" a waney edge
Steve
No skills":1gjelyvs said:Interesting indeed.
Do you allow for any 're-finishing' when pricing this sort of furniture (slabs) ? I've often wondered what happens if the slab behaves unexpectedly in its new environment and customer becomes unhappy with the overall flatness of the item.
custard":euiuml6r said:Wizard9999":euiuml6r said:If I understand the sequence of events correctly components are machined, joint positions marked up and then domino mortices are cut. You then mention cleaning off the pencil marks, etc. either by planing, sanding or both. I guess this is the point at which your 0.5mm allowance comes in? Having gone to such an effort to ensure the perfect alignment of the components with your shimming, etc. how do you deal with the risk that the planing / sanding doesn't introduce inaccuracy?
Fair question Terry.
If you're doing subcontracting work on cutting lists, components, or sub assemblies it's fairly common to be given a +/- 0.5mm tolerance. It makes sense to initially hit the upper limit and then have the maximum amount to play with if you have to correct any problems. I guess I've just carried over this practise, but you're right, 0.5mm is a generous allowance just for cleaning up.
As to introducing inaccuracies, as long as you sand or plane the entire surface evenly with overlapping strokes it's not a problem, a domino automatically plunges about a mill deeper than the length of the domino tenon, and all the joints still close up with airtight precision.
JandK":13v62g37 said:Thank you Custard for a very informative thread well worth reading, there is a lot to learn from this thread.
It has also brought back a lot of memories from my youth in South Africa. On the farm in the Limpopo province where I grew up this tree was mainly used for fencing posts because of its durability, the timber is resistant to termite attack. My grandfather planted a lot of the posts during the 1930's and they are still standing. People often said that if a termite bit into the heartwood it would need to see a dentist urgently![]()
The wood is some of the best to use for a bbq.
It is also the choice wood for carvings and some excellent animal figures of buffalo and elephant can be bought for very little money in Zimbabwe.
