lathe
As James said, please do not buy one of those Clarke etc (lumberjack, vevor etc) lathes with 2 square bars for a bed. They really are rubbish.
You need to careful about such generalisations to a beginner.
It's true that there are a lot of dirt cheap generic Chinese lathes with square tube bars that are best recycled into tin cans.
However there are some fantastic old British built lathes with solid square bars that are absolute bargains secondhand. The Myford Mystro referenced above is excellent, also the Tyme Avon and Cub are great lathes that change hands now for less than a round of drinks.
There’s a set up being sold on the forum just now which might suit you. Good price for what’s included. As previously stated, you’ll need to think about dust protection and sharpening, but it wouldn’t you started.
Also, a really good way to start would be to find a local turning club and go along for a few weeks/months. You’ll get to try different equipment, get some cheap/free instruction (important for safety tips, if nothing else) and members often offer things for sale cheaper than you’ll find elsewhere.
However there are some fantastic old British built lathes with solid square bars that are absolute bargains secondhand. ....
Yep i got an Arundel J4 Senior with a 6ft bed and extras for £100. It's a brilliant bit of British engineering and a pleasure to use. Only 4 speeds but there's nothing you can't do. The J4 Junior is also excellent.
There's a J4 here looking good but overpriced perhaps. https://www.ebay.co.uk/itm/335747479505
Another one on Ebay is wrongly titled as J4 senior. I'd wonder about £100 perhaps.
Thanks for your very much for your advice. I am taking it in.tyvm
With that budget I would definitely suggest second hand. Also, consider what size items you are likely to wish to make. Fixed head machines can be very limiting. The myford ml8 will only manage 8 inch over the bed and 12 outboard (which will need a left hand threaded chuck / faceplate). If you only want to do spindle work this may be of no consequence. If you want to make bowls, this will feel really small really fast.
I learned on a version of this (axminster m900 and clones) and always suggest it as a decent balance between cheap, sturdy and capable.
https://www.ebay.co.uk/itm/17678723...gcasv-DSI6&var=&widget_ver=artemis&media=COPY
With patience, you should be able to pick one up for around £200 which leaves you a bit for tools + sharpening
Thanks for your reply I am grateful for your help and all the other people who have given help as well .tyvm
4 speeds! Bleeding luxury that is. I started with a 3 speed Record. Still did the job and I basically learned turning on it. I did trade up after a year not because of the 3 speed but I wanted to turn larger lumps of wood. Current lathe is still belt change but.a couple of extra pullies. Doing fine after 18 years of use and will likely see me out.
John
Don't underestimate the cost of tools, chuck etc. If you see someone offering a 'deal' with these included they could very easily be worth as much as the lathe itself, when you consider a new HSS bowl gouge could well cost around £60, and a chuck could easily cost £200 plus jaws.
I have a Myford ML8 and it is a solid, well built machine, as indeed it should be considering at today's prices it would be over £1000 to buy new. Early ones are yellow, then they changed to silver, and finally green before productopn ended in the 80s. Mine is yellow, so probably 50 odd years old, and still good.
Also, factor in the cost of a sharpening system. A bench grinder is a good start. Get yourself a copy of Woodturning, A Foundation Course by Keith Rowley. You will find plans for a home made sharpening jig in there as well as a wealth of other useful information.
Welcome to the money pit, and do enjoy your woodturning.
K
Spot on with the cost of additional tooling or accessories. These can cost as much as the lathe. I like the ML8. I had a green one but sold it for something smaller. Wish I hadn't. The only minor irritation was that the bed tube could get full of shavings causing the tailstock to jam when moving it. Easily minimised by draping a cloth over it.
Be careful with old lathes. Some have strange spindle threads. If you see a bargain make sure you can get a chuck to fit it. Adapters are best avoided.
That's the trouble with second hand lathes I will not now what's right or if it's a good bargain. I think I will go for new .I will get a small one to start of I don't now which lathe to go for Axminster or record power.
Tyvm for all your help.
Hello,
If you need some tools to use with it - with regards to chisels I have a lot to get rid of as I have too many
