matt_southward
Hey Chaps - I'm looking to upgrade from my current setup - a Record CL3 (new version). I've been fairly happy with the CL3 but wanted to upgrade to variable speed and whilst I was doing that, upgrade to something with more mass (the Record stand is laughable and not fit for purpose). So I've been looking at new lathes, which are pricey but look great, or a Union Graduate long bed.
I turn bowls & spindle work but want to be able to get in greenwood logs for bowls and the Record just isn't going to cut it without variable speed; and I've been so disappointed in the stand that I've been put off Record altogether.
So I have a few questions about the Graduates that I'm a bit unsure of:
- turning outboard - how do people go about this? Do you learn to turn left-handed or reverse the cut on a normal right-handed stance (if that makes sense).
- again outboard - obviously with variable speed there's the option to reverse the spindle direction, but then you need a chuck you can lock onto the spindle with a grub screw - I can't see if that option is included on the chucks I've looked at does anyone know if any do?
- I do like the option of a rotating headstock (very common nowadays and something I'm used to), but the Graduate offers an alternative option - though it's a bit different to what I'm used to. Does anyone have experience of the pros and cons of both?
I'm sure I've other questions, I just can't think of them at the moment - any comments on the above issues that help me get my head around it will be gratefully received!
