Lathe stand for £13!!
Steve Blackdog
24 Mar 2008
Cumbria
I have a productive weekend. Alongside doing the garden with (for) SWIMBO, I built a very sturdy stand for my little CCSL lathe.
I made it entirely from old construction timber off cuts. The only thing I paid for were the 24 M10 coach screws that hold it all together. I was ripped off for them at 40p + VAT each!!
It ain't pretty but it does the job bloomin well. The lathe centre is now at the perfect height and there is no vibration at all. I can't believe the difference.
Currently the lathe is sitting on its rubber feet which are on M10 threaded bolts. I am planning to screw it to the stand. Any views on the best way to do this? I'd like to keep the ability to adjust the feet still.
Cheers.
Steve
Cheers.
Steve
Yes pictures would be great to view.
Thanks Tim
Okay, I'll try to work put the picture thing. But don't get excited. I never said it was a piece of fine furniture!! You will have to wait a little while ;)
Steve
Here's the pic - as I said - function is the key to appreciating this stand. I propose to add bags of gravel to the shelf to add weight if needed!
You can just see the feet on the lathe. I am thinking of adding a 400 x 1000 plywood top, but this works very well at clearing the shavings.
All the best
Steve
    53.5 KB
Here's another view, showing the high degree of precision engineering at play :wink:
    22.6 KB
thanks for the pics
you sure splashed out on those bolts - I made mine from old construction timber too; but only 4 bolts (and a bit of glue and screw). Then I ruined the cost saving element by adding wheels!
hi
looks good, i am just about to sell my ccsl lathe and chuck so i hope whoever buys it reads your post..
