Lathe DRO on my DIY router table
Gadjet
10 Jul 2019
Cheshire
I'm putting together a router table with a Enjoywood lift from Banggood and so far it's going well, I also have a lathe and I thought I could use a DRO on the lift to measure the cutter height.
It fitted really easily using an existing hole on the lift.
I did this with a Wixey DRO which is made for this purpose.
See the small bracket on the bottom left corner …
That is the Wixey DRO folded back … and now flipped up …
To use, first install a router bit …
Lift the bit …
… flush with the table top.
Now set the Wixey to zero …
Finally, raise the router bit to the desired height. Here it is 6mm (one can work in Imperial as well as Metric) …
Regards from Perth
Derek
Regards from Perth
Derek
Looks good, I'm going to see if I can design and 3D print a mounting bracket for the display so that it sits under the table and maybe make it slide in and out so it's protected when not in use.
