Waka:
Not sure exactly what you're asking. First answer is how the glass is fitted, second is how the top is constructed,
The top is 3/4 maple and I fitted a strip of padauk around the inside of the openings flush with the bottom edge of the maple and 6mm down from the top surface - so that 6mm glass would give me a flush finish. The padauk is glued in place and additional security is provided by two brass pins and one small brass screw in each strip. You can just see a screw head in the corner photo. By the time the top is patterned the screws and corner leg brackets will be concealed. The glass is a 'comfortable' fit - when cut they were about 1/32 too large so I had the edges repolished and now they drop in nicely.
The top is made with half-lap joints that go one thrid way across the long edges (so they don't show). They are glued and screwed underneath. The side rails are biscuited into place every 10" and the corners are reinforced with the leg mounts - steel brackets. It's pretty strong, given there's only about a 1" joint at each corner once the cut-outs for the legs are made. The legs sit up about 1/8" above the surface, sit out 1/4" on the front and back edges, and are almost flush at the sides - maybe 1/64 protrusion for a nice 'shadow line'. I designed it that way for the space where it will be used. The joints at the legs are feathered to disguise any minor imperfections in the (hand) cutting.
Hope this helps.
My only concern is that the legs are secured with a single bolt (screw one end into the leg, machine thread the other to take a nut) and for the size of table it seems to be a bit on the minimal side. However, it is reasonably solid and won't have to take any rough treatment so it should be fine. If I was to make another, I'd use two bolts per leg just to be on the safe side, especially if there are children around..
