Last question (I think)
sunnybob
wysiwyg
11 Oct 2014
cyprus
Showing my ignorance yet again, whats the background on this saw, and its correct name please?
I can see its a Tyzak no 120, but thats the full extent of my knowledge.
As it's a 'Ltd' and not Nonpareil that normally dates such saws to probably later than 1906, and with this example, the more modern engraving, plus the disc around the medallion, plus the rather crude lamb's tongue means it is almost certainly a 1950s to 1960s saw. Nice piece though and worth hanging onto if you use hand saws at all.
Tyzack & Sons actually operated from 1867 to 1990.
Your saw blade I assume is 14" / 35cm long, with around 10-11 teeth per inch? If so it could go by two names, either the commonly and normally used phrase 'tenon saw' or to be more specific, a 'sash saw' was historically used for a saw of around 14-16" long (longer were tenon saws, shorter were carcass saws, followed by dovetail saws being the shortest at around 8-10")
Very helpful, thanks.
Non parell is stamped onto the metal along with a crest and something that looks like "monesses"
I have tried a test cut and although it cut smoothly, seems blunt. I dont have a fine toothed saw so this one will actually be kept. I have no idea how to sharpen a saw, I assume theres a thread here somewhere?
Can the blade be taken out of the brass spine? or is that a step too far for someone as inept at restoration as me.
I would strongly recommend not learning to sharpen saws on a fine tooth DT. They're tricky (and hard on the eyes)
[/quote]
It can, but it shouldn't. You'll never - quite - get it back right, and since that blade is quite clean, I'd leave it "as is" for cleaning. Just a bit of tinfoil and solvol should do it.
BugBear
Yes modern - 60s or later.
Also well used - the taper shape is the result of many sharpenings, as follows;
Saws tend to wear most in the middle. It makes more sense to straighten the edge by taking more from the toe rather than the heel, or you run out of clearance under the handle.
Also well cared for as it shows little rust. In fact it needs no attention at all except sharpening and a wipe over with linseed oil.
Sharpening done by feel - easier than you'd think but you need practice on larger saws to begin with. Felt tip helps - you can see where you've been.
Hah! I thought it was meant to be that shape.
I'm having major doubts now that i will do anything with this, I just am not prepared to learn yet another set of skills at my age.
If I ever get around to making something by hand that needs this tool, I might reconsider. I shall leave it on the wall with the other saws.
thanks for all the knowledge.
I'll sharpen it for you for nowt Bob. Be my pleasure mate. :D
I could do with practicing on someone else's saw before trying my own saws for the first time. I don't want to mess my saws up after all. That would be daft. 8)
Thats very kind of you, I'll send it first class registered from Cyprus, marked C.O.D. as soon as your £200 non refundable deposit cheque arrives.
I have six others as well, i could send them one at a time so as not tax your reserves.
I think the tapered effect has been caused by the plate being driven out of the spine at the heel end by rough treatment of some kind. The writing on the spine should be parallel with that on the plate, as in my photo below. You should be able to correct yours by holding the plate in a vice and tapping downwards at the end of the spine. With a little work you will have a very good saw.
    247.2 KB
Bit of both perhaps? It's a style of sharpening you see a lot like that - but the end of the plate isn't square to the spine so might have been forced in too? But you shouldn't be able to force it in that far. Dunno - a mystery, some sort of deliberate modification?
I've got one that looks similar to sunnybob's (not Tyzack, another make) and looking closely I can see that because the front of the spine has been forced too far down, the back of the spine nearest the handle is also too far up, and barely gripping the blade, a kind of see-saw effect - this gives the illusion that the blade must be non-straight, where in fact it almost certainly is straight, on mine anyway.
I don't yet have a suitable vice though to do anything about it, so one of those 'round tuit' projects.
Hmmm, I might have time to investigate further tomorrow. The blade is perfectly straight, but the brass spine looks like its had a few beatings in its life.
This thread might be interesting
c-nurse-dovetail-saw-restoration-t99984.html
As I said there, what has happened is that the plate has become too deep in the spine towards the toe by repeated straightening using hammer blows to the spine. The spine may have pivoted up at the back a bit too in the process. The plate is not supposed to be bottomed out in the fold of the spine, the spine is only meant to grip maybe 1/4" of the plate.
I'd bet the plate is not tapered, if you were to remove it from the spine. The Bad Axe web page I referenced gives more info, and how to correct it.
I've had a very brief rub over the saw with wd40 and four0 steel wool.
The brass rib still has most of its lacquer on it which is why it looks so worn. Aparrt from a couple nicks at the front end, its quite good.
The blade has markings of "sheffield steel" to the left of centre. An elephant in a badge over "non parril" in the middle, and "tested for hardness" to the right of the badge.
I think if I start to "refurbish" it I will lose most of those markings so I will leave well alone here and just use it.
