Only having used a lathe for metal work is there not a woodworking equivalent of the boring bar?
Not if you break the center out, but that might be awkward 250mm deepHole saws are limited by their depth, mine all tend to smoke a lot too... Need new ones
Have you tried Axminster tools.Hi there,
I am looking for a quality forstner bit with a 70mm diameter. I know Fisch do them, but i cannot find any company in the uk that supplies that size. Anyone out there know where I could get this, without going into Europe.
obviously I could use a smaller bit and then hollow out the rest, but I need to go about 250mm deep.
Thanks, Dirk
30 mm to 70 mm with a 350 mm depth of cut are reasonably easy to find and not expensive, they are designed for cutting concrete so will have no problem with wood they are designed to be used in an SDS drill but can be modified if needed. You will need to break out the core at regular intervalsHole saws are limited by their depth, mine all tend to smoke a lot too... Need new ones
These look pretty sturdy30 mm to 70 mm with a 350 mm depth of cut are reasonably easy to find and not expensive, they are designed for cutting concrete so will have no problem with wood they are designed to be used in an SDS drill but can be modified if needed. You will need to break out the core at regular intervals
They are, the grind on the carbide is not optimised for cutting wood but they will certainly do it, though you will probably be backing them out for chip clearance often. You might be better off with the Bosch or Lenox saws with an extension bar. I didn’t get the 70mm as I only need the 35mm & 50mm ones. They cost about £15These look pretty sturdy
I think a combination of this product and my DVR motor is a winning team, journey to the centre of the earth....... How clean is the cut I wonder?They are, the grind on the carbide is not optimised for cutting wood but they will certainly do it, though you will probably be backing them out for chip clearance often. You might be better off with the Bosch or Lenox saws with an extension bar. I didn’t get the 70mm as I only need the 35mm & 50mm ones. They cost about £15
View attachment 107462View attachment 107463
