What brands do you class as the better ones of the bunch, I have used Western Digital for both mechanical and M.2 SSD and so far never any issues but my SSD is only my OS / programs drive.
To date - as a user of "only" Crucial SSD - some replacing traditional HD - happy to say that all of them after many years of use are still going strong.
When I was one of the mods on a now (sadly long gone computer forum) the whole issue of SSD was a regular event. The SSD gurus advised that an SSD (when not in regular use) need(ed) to be powered up every once in a while (at least once a year) to preserve the data. That the cheapies didn't cut the mustard as the saying goes; and it is worth the extra dosh to get a make that was reliable.
The one thing you do NOT do is to run any form of of defrag utility...
Also if there is data on any HD/SSD that regard as serious long term storage - consider to use an NAS to secure it alongside an external backup of the NAS( to an external HDD); and also for stuff like photos/videos burn to DVD (even 2sets). Store those DVD in a safe place and separate from any other long term storage system/s - just in-case...
Simplest NAS is a mirror system; two drive with identical content. If one fails then after replacing the failed drive the "mirror" will rebuild the system to two identical drives. Some advocate SSD for NAS; most broadcast outfits, for example, now use SSD in their NAS; but other arena/places etc. still favour high spec HDD... WD make excellent HDD for NAS systems - three grades; and worth investigating there if going the NAS route.
As most laptops and desktops now seem to have some form of glued in (i.e. soldered) SSD... I'm inclined to wonder just how long these devices will last, before either the MoBo is replaced, if not the whole laptop/desktop... Gone are the days when one could replace a failed HDD/SSD.
Anyone know how to securely erase an SSD that has gone into read-only mode before I return it.
Samsung - not Crucial - and I am doubly hacked off as they reneagued on a rebate offer as well.
Yes the earlier Gigabyte ones have two, the latest ones look to have four.Most PC motherboards I've seen recently have M.2 mounts
Yes I had some external drive that was supposed to behave as cloud storage that just would not work with Windows 10 and had to be sent back, to remove the data I just put it in the microwave for a few seconds.It's very tricky to get right. Generally, you need to either physically destroy the drive
Have you tried booting a Linux Live USB and wiping the rogue SSD with that?My model of SDD is supported - sadly Linux is not. Ho-hum - I will have to see if a Virtual Windows does the trick.
Thanks - yes - it is actually out of the Linux computer - it went into read-only mode on that.Have you tried booting a Linux Live USB and wiping the rogue SSD with that?
Far too much work!My employer drills holes through them...
Why not? Might stop someone else from using them.I'm not going to name the outfit involved
They were a very unprofessional outfit, one of their remits should always be the protection of customer data and to recover whenever possible and not just wipe it.I recently took my laptop in for repair, all my work was stored there, the problem was with the cooler, but they changed the disk and all the files were erased.
That's truth I'm thinking filing a complaint or seeking a resolution with the service provider, as they should be held accountable for mishandling data.They were a very unprofessional outfit, one of their remits should always be the protection of customer data and to recover whenever possible and not just wipe it.
