thomaskennedy
Hey there...
After spending the last 2 days in the workshop i made the Lap Desk that Charley has plans for in the free plans section of Tool Box...
I began with some maple i had left over from the Coffee Table i made a few weeks ago (which is still not 100% complete [-X !)
The Maple was 125mm wide, and 30mm deep. I used one length of 800mm and one length of 1520mm to make it, i had to 'edit' the sizes a bit but it has turned out OK!!
So to begin with i cut the wood to approx length on the chopsaw and then ripped them 2/3 mm too wide on the bandsaw to clean up on the jointer..
Here i am about to begin planing and thicknessing my wood
After a while i have all my wood planed on 3 sides ready to be thicknessed to 19mm..
After my newly discovered world of lovely snipe and a bag full of maple chippings,
They'll do for the hamster eh? :wink:
Now i am ready to cut them to the final lengths, i am at the chopsaw measuring up,
After 'Measuring Twice and Cutting Once' :norm: I am left with a pile of lovely clean square maple..
I then used my Tapering Jig from Axminster to cut the sides...I forgot to take pictures of this :roll: but i did it nevertheless...
Now i am ready to glue up....Now about the dovetails...
There was a little accident i had with those #-o ... I had the dovetail jig all set up and i cut the first corner, and then the second..BUT..i made the horrible mistake of putting the piece in the wrong way round so i had to use but joints to avoid making the desk any smaller...
Now aside from the ONLY mistake i made i can get on with the glue-up..using standard PVA i clamped up the sides....
Whilst thats in the clamps i use the jointer to ensure i have a good edge to clamp the top with.. i then set that in the clamps...
Once all is dry i can now glue and clamp the top back of the desk on..
Whilst that is drying i can begin to cut the breadboard edges to length along with the correct angle to hinge it on the top back..
I achieved this by simply butting the breadboard edge up to the top back, and then i cut a thin bit of wood (around 8mm or so) and i put that bit of wood against the top back and pushed it up to the breadboard edge, and, using a pencil, strike a line against the breadboard edge to create a vertical line..
Then i set up the chop saw at the angle that i have just made on the breadboard edge,
Which turns out to be 13 degrees
Then i cut both breadboard edges together to get the same angle..
Now then, in order to get the correct angle for the the rest of the top, i needed to set up the bandsaw at the same angle as the breadboard edges,
With the bandsaw set at 13 degrees i can now cut the top,
With the angle cut I am now ready to glue the breadboard edges to the top...
I left the top too big, to cut down after the glue has dried....
Once the glue dried i then cut the excess off the top on the bandsaw and cleaned up on the jointer..
In order to achieve a crisp angle i decided to set the jointer at 13 degrees to plane it to a nice level and even angle..
I then sanded the it all flat and smooth..
Next up was to make the base... I opted for 4mm Ply.. I cut it to size on the bandsaw then sanded the surface that was going on the inside and then glued it down and tacked it with a few pins..
Now it is starting to take shape..
At this point i decided to add a front edge to the top...This will stop the paper/pen or whatever is on it from falling off..
This shows the edge where it will go..
And here is it in the clamps...
Well i thought i'd share with you one of the kittens our Cat has just gifted us with \/ ...
There are 2 more but there just boring, black, and black with a bit of white :roll: O .... :wink:
Enough of the aww-ing..time to get back to work...
Now the glue is dry i am ready to attach the hinges...
I set the hinge in place then drew round it with a pencil (don't ask why i marked for the holes aswell :? !)
I am left with this..
Now i used a large chisel and a hammer to begin cutting the outline..
then a smaller one for the edges... Then i chiseled some lines across the rebate to help clean it out...
(this is the image of the hinge cut from the opposite part of where the hinge will go)
The rebate is now complete and the hinge sits in fine..
Then i went on the do the other one at the opposite end...
Now then in order to get the hinge in the correct place on the other part i positioned the top where i would like it to go... then I made a small pencil line where the rebate was on the top...
You can see this in the following picture...
I did the same at the other side...
I followed the same routine with cutting the hinge as on the top...
Now before i jump in and cut the other rebate i decided to double check that it was in the right place...
I attached the hinge on the side that i had just cut, so as the lid was swinging on one hinge,
I found that it was around 2mm out (as per image below), so i remarked it and cut the rebate as the others..
I then fixed both hinges in place and i now have what resembles a hinged lid..
Now there isn't much left to do really... Just some final sanding and a finish...
Oh and one more thing (this need only apply to me) to cover up my dovetail mistake i added some quadrant to the inner corners..
I just cut them to length on the chop saw and then nailed and glued them in place...
For a finish i used beeswax...
Now then to add a bit extra to it i decided to add some self adhesive felt that i got from when i went the Tools 2004..
I think it turned out OK... I have placed a few pics below of the finished piece...
If you actually managed to make it this far then please give me your opinion
Ta
Tom
ps. Apologies if i missed anything :shock: 8) :wink:
And i also painstakingly changed all the picture sizes :evil:
Ta
Tom
