ok, not suggesting the connector need earthing, but the light fitting
might well see whether there is an extra screw thing at the bottom
of the light fitting just above the threaded portion where the wires come
in.
basic lesson in electrics, almost ALL small equipment needs less than 13 amp in the fuse, even many tv's, hi fi's, radios etc
formula is watts/volts equals amps from memory.
because of the eu rule about plugs wired onto equipment these days, too many people overload their circuits by not de rating the plug.
think about this logically, if there is something wrong with the appliance,
then you want it to fail as near to the plug as possible, not at the main
box where getting there could be a hot wire that might set light to furnishings etc. about the only things in my house that have 13 amp fuses
are the fridge, freezer, and washing machine. even the microwave is only 5 amps.
mind you my router has a 13 amp one but it is 2000 watts. see how it works??
make sure your check your solder joints again.
finally, are you sure you checked the wiring notice that came with the
connector, and have you connected the plug wires properly??? :?
hope that helps
paul :wink:
