oddsocks
I've recently fitted a new kitchen including laminate floor (from Wren kitchens). I laid the floor (including the supplied foam/foil underlay) about 6 weeks ago onto the old stuck down lino (the previous glued laminate had been on this for 10+years). Everything went down great and I took care to ensure the boards were not damaged on the glueless profiles. Now, and after all the units etc are fitted, a couple of the boards have 'split at the seams' on the long edge, such that one edge is about 0.5mm higher than the next board and when you walk on it you feel it move. (back down to level). I have some laminate offcuts so joined them and can only assume that part of the mdf profile has failed thus creating a movement gap. Unfortunately lifting the floor now would be extremely difficult due to larder units, range cookers and end profiles on the floor supporting the worktop. I did leave 10mm expansion gaps all around the area and these are still visible.
I have already tried thin superglue and a ceiling prop to apply pressure whilst it set, but this only lasted a couple of days....i'm now looking for the next 'least destructive' repair. I do have some large printer ink syringes and wondered if anyone could recommend a thin epoxy that could be syringed in (if needs be I'll make a 2mm hole) that has both good gap filling and bonding properties. I have got normal car fibreglass resin and a white (dries clear) hardener but have been advised that that resin needs fibremat for strength,
Would the west epoxy system be thin enough and suitable?
in hindsight I should have purchased a more solid underlay and not used the 2mm soft foam/foil that Wren supplied, as it does flex where the unit legs are..mind you the area with the issue is not that close to those areas so I don't think its transferred pressure.
Dave
Dave
