Westy619
Hi all,
first of all I have yet to highlight any of these issues directly with the UK arm of Laguna, but plan on doing so this week.
My saw turned up at the end of November after a 5 month wait from ordering it in May. On top of that, I had to pay an additional £250 due to global price rises and shipping costs (or so I was told) taking the total to £2699 including the wheel kit and 3 blades. I thought fair enough, the seller couldn't absorb all these rises and I didnt fancy waiting another 5 months for something else.
After it turned up, I unpacked it but didnt do the final setup or turn it on. Having finally got some free time this past week, I went through the process of fitting a blade and checking the machine all over. This is where I started to notice some issues.
First of all, the table was off by around a mm over its length with a hump in the middle where it attaches to the trunion. I dissasembled and found the milled section of the trunion wasnt flat, I took a round bar with adhesive sandpaper wrapped around it and took light passes until I was hitting all 4 of the milled surfaces. I then removed the mating cast aluminium parts bolted to the underside of the table. Here I discovered a thick layer of black paint on on each of the milled flat surfaces where they attached... I proceeded to scrape this off back to the metal and reassemble. This improved the table but when tightening the table to the trunion it was still pulling one side down further. In the end I used some brass shim stock to make everything level. A lot of work for a brand new, almost 3K machine I thought... surely it cant get any worse! I fitted a blade to the machine and turned it on, there was so much vibration that the blade was visibly whipping from right to left. Additional dissassembly required....
I measured the front face of the lower wheel with a dial gauge and for about 0.15mm of deflection, not sure if this is good or bad to be honest. I removed the lower wheel and found rust between the arbor and the in race of the bearing. I tried to remove the top wheel but it was absolutely stuck to the upper arbor.
I eventually managed to pry it free only to find the back bearing had come out of the wheel housing and was still stuck to the arbor. In the end I removed the arbor and pressed the bearing off only find a lot more rust... I've ordered replacement bearings for the upper wheel as I cant reuse the originals in their current state.
So, to summarize, can I get some recommendations on common causes of excessive vibration in bandsaws as I don't even know if the issues I've found so far are the route cause...
