Jacob
What goes around comes around.
People spin arguments to suit their position. Wildfires go by many names are are common across the globe and often natures way of regenerating. https://en.wikipedia.org/wiki/Wildfire
As with most things - the experts tend to be the people who have studied and learned about the science, as Tingley seems to have.Who knows what the real reason is?
The point is - efforts to mitigate CC effects are being overwhelmed, LA and elsewhere around the globe.The people of California who are affected by the frequency and severity of these fires don't need to be told for the umpteenth time why they are happening. They need actual measures in place to control the situation and mitigate the effects .If one finds oneself in the midst of something like this , then the worst is already happening - whatever the cause.
Given that California is the wealthiest State in the whole of the U.S.A. then funds are going to have to be channeled into better managing the land outside the major cities - all those wild, forested areas and, grassy scrubland. The minimum one should expect is that there are, at least, large enough fire-breaks around the major conurbations to protect them.
Interestingly - the number of fires is declining but the extent and intensity of them increasing. https://www.google.com/search?sca_e...HZSdKQkQtKgLegQIGRAB&biw=1398&bih=724&dpr=1.8I suppose you have to look at the data of fires in LA for say the last century. A graph will easily show if it has been steadily increasing.
TBH outwith the last decade, I cant remember any reports of LA going up in flames on a yearly basis.
Yes they shouldn't have built there, or would prohibiting barbecues have been the answer?If you cover a arrid area that is a tinderbox with lots of houses that are fairly well packed in, know you have a shortage of water and yet still allow barbecues then you are setting yourself up for such a disaster. If someone had looked at this problem and thought about fire breaks then the number of dwellings would have been halved and fire breaks put in certain locations to contain a fire.
Reports today that some of the fires are arson.
Nothing wrong with building there if the houses were spaced out much further apart and the overall layout was good to prevent the spread of fires, the actual problem is the reason why they did not do this which comes down to greed and making the most money at other peoples expense. This is also a reason why we will not see houses built in the Uk that are really energy efficient because they have larger footprints and a developer would have to build less on a given plot of land which would not keep the investors and shareholders happy, so build anywhere you can get away with including flood plains.Yes they shouldn't have built there, or would prohibiting barbecues have been the answer?
