Bodgers":2trk2umx said:
D_W":2trk2umx said:
No slight to the fellow, but a hand forged iron deserves a plane that's not glued together (one with a wear would be an improvement, too).
What is the disadvantage of a glued plane, vs one made out a single piece?
I notice The English woodworker has plans and a video series on making a wood jack using the glued method...
You end up with an inferior plane that has the potential for creep and movement (but the inferiority isn't just due to glue). I saw that Richard decided to sort of junk it up with an accessible plane design, but most people watching his videos would be better of watching mine - not to make a plane - but to buy one of the many fabulous used low-wear wooden planes that you guys have left over there and do a once-over on the wedge, iron and cap iron and sole. You'd have a better plane for less money and much less effort. You'd actually have a lifetime plane that you couldn't really improve upon, even if you went so far as to build them like I do.
I think Richard was probably looking for accessible when he made a plane glued together with a cross pin and in at least one, used a stanley iron and cap iron. I get it from his perspective - he can't turn around and suggest that everyone copy a holtey plane with holtey's accuracy constraints, but I have issues with those compromises (cross pin, wrong style of iron, etc) because a plane like that will not perform as well, especially if you get into heavier work with it. The fact that it may come apart or creep over time isn't really that big of a deal, you can lap the plane from time to time and remove any glue creep problems, and if it comes apart, you can just build another one. Mortising a plane out of properly sawn wood (a single piece) exempts you from any of that ever occurring, though. And it's a lot easier than it seems. Using a proper tapered iron and cap iron means that the fit, support and nuances (how the fingers terminate at the top of the cap iron and don't create clog points, but don't have to terminate short of the end of the cap to do it, how the wedge and tapered iron and cap work together for adjustment etc) are all as they should be. They're all the way they are for a reason.
A glued-together plane is destined to be set aside by a serious woodworker. I made duds before I made good ones, and making duds and then setting them aside is what drove me to figure out how to make good ones. "Oh, but they're easier to make" doesn't go that far if you find yourself making a half dozen turds in the same time that you could've made one or two good ones that you'll actually use.
