Kity 613 Bandsaw wheel removal
Not sure but thought the top bearing was captive with a circlip?
Found this picture. If you can zoom in I think you can make out the circlip
    51.7 KB
Yep, can see the circlip, not sure how tight the bearing will be pushed fitted onto the shaft though.
Would like to get the shaft out as well as may well have to send it away for a new tyre.
By the way, tried getting the circlip out but as of yet have failed spectacularly well!
Sounds like you need a circlip plier set and a bearing puller. Usually these sorts of thing are an interference fit so relatively tight.
Worth popping on some goggles for removing circlips as they can go with some ferocity
So you're not using circlip pliers?
After removing the circlip, the wheel should just pull straight off.
... and why not buy a tyre and fit it in-situ?
Make a tough job ridiculously easy...
http://www.ebay.co.uk/itm/4-IN-1-CIRCLI ... SwfVpYoIcP
I think the wheel will come off with a bit of gentle persuasion once the clip is removed.
The tyre can be changed in situ, no need to remove the wheel. If the wheel makes a grinding or clicking noise when it spins by hand, replace both bearings. A really simple job that is unlikely to need anything more than a hammer, a couple pieces of wood, and a flat workbench.
Think I need a new pair of circlip pliers as the damn thing keeps letting go just as I'm getting the clip to come out.
Hopefully, will not need a new tyre, but I need to get the wheel off so I can clean up the residual rubber(?) mess left on the wheel when the lower drive wheel tyre melted and transferred it all to the top wheel via the blade that is also knackered.
lesson learned never try to saw 3 layers of mdf stuck together on a band saw!!!!!
I made this for the job:
There is a nut let into the wood somewhere on that middle bolt. Just wind the bolt in with a spanner and the wheel pops off. It was impossible to remove without this bit of kit.
As a matter of interest where did you guys get the replacement tyres from and were they straightforward enough to fit?
TC
OK guys just a quick update.
Circlip out, puller bought, fitted tightened, then tightened, then tapped,(walloped),with hammer, then tightened then heated then.......... still bl**dy wont come off.
So, took a closer look at the other end of the shaft and could just see a pin that appeared to hold the complete shaft in place, knocked out the pin through the small slots in the cover and out she came, wheel and shaft.
Have totally given up trying to get the wheel off the shaft, reckon I will break the flange before it let goes the wheel.
Anyway, took yet another look and could see 4 small screws that appeared to hold the cover on, great thinks I, nope, they all just turned without unscrewing, so sod it, cut the heads off and voila the cover is off and I can see how to refit the shaft before cover goes back on. Reason why screws just turned, well someone, (Kity), must think an ordinary bolt will fit into a speed clip and be able to come out again easily, wrong!
Anyway, though I'd give you an heads up on how to strip a Kity 613 bandsaw upper wheel.
NEVER AGAIN!!!!!!!
