As I said in the article, ".... medium-density fibreboard (MDF) throughout, because a painted finish was required." All carcasses were 18mm MDF, the sink base 18mm Medite (water-resistant MDF). The bottoms had 9mm x 9mm rebates, as did the sides, fitted with the sides on top of the base rather than overhanging it. The backs were housed in 9mm trenches all round, inset 50mm in order to give a plumbing recess at the rear. 18mm rail across the front, 18mm nailer at the back where applicable. The drawer unit had a 9mm back panel, inset 15mm to allow for scribing. The sink base has a slot-in 6mm panel which allows access to the valves, etc.Roger Sinden":1deyklaz said:What did you make the carcasses from? MFC? Any particular jointing technique?
The boiler is quite tiny, but still requires specific clearances all round, unless the base is removeable.Any chance of more details about how you fixed the door panel over the boiler for accessibility. Does it come right off?
It's in an outbuilding.Simoli":1azgw1hw said:Is that a clothes washing machine by the sink?? If so where is the dryer?
