Bodrighy
I was given three very narrow spindles of lignum vitae, about 6mm thick, didn't know what to do with them so had a play and made this trembleur. It's 46" long not including the bird thing stuck on top. As I said just a bit if fun seeing how thin I could go. The thinnest parts are about 2mm thick the widest are 6mm. Base is a scrap bit of yew and the weight on top is ebonised hawthorn. Mostly done with a skew working with the spindle inside the head held close to the working point.
Sorry about the photos, I took about a dozen trying to get a decent photo but failed, hopefully you can still see enough to get the idea. There is a small hollow ball between two sections and a captive ring on there made with a dental pick
pete
![](https://proxy.imagearchive.com/24d/24d010ce1d82738942c0678870c5c401.jpg)
![](https://proxy.imagearchive.com/6fa/6fa68a571a2fcfb2d4929c9877bedd15.jpg)
pete
