My carpentry skills used to be pretty good but am a bit out of practice, I'm building a cot and I've finished on merging two designs, a combination of wood available and the design finishes.
The end panel is going to be 68x20 side uprights & top rail (American White Ash) with 120 x 20 horizontal rails to make the internal panel.
This image is something like it,
but the top will be a flat 44x20 with a rounded edge like the one below
Any suggestions on how to construct the end panel? I was thinking dowels or Mortice & tenon, unfortunately because of the milling wastage my top rails are too short to go right across , so it'll have to be the side rails right to the top , but with the top moulding I think it'll look ok.
Something like this, excuse my not to scale sketch , I was thinking of V joint finish, I don't have a workshop but I do have a router, and am getting a router table to round off the side slats etc, I also have a biscuit cutter. So far am thinking some kind of simple central rebate in the sides then tongue the cross rails so they can slide into place, then maybe a few biscuits to join them together, or a small 5mm half overlap rebate but I'm worried about them splitting or movement. as this isn't really a thin panel should I be concerned? the biscuits will be simple and keep the wood together of cramped up ok?
Really appreciate any advice as I said its such an important job and I'm nervous of getting it wrong. Last thing I'm not doing a drawer ..
Many thanks
Alan
Many thanks
Alan
