Jigsaw recommendation for skateboard ramp.
timothyedoran
9 Jan 2017
Bradford on Avon
I would be super grateful for some advice about jigsaws. I don't really want one as I won't use it much but think I need one to build a skate ramp like this:
I don't think I could cut the curves with a hand panel saw.
I had a cheapo jigsaw that cost about £15 15 years ago and it recently died. Only reason it lasted so long was lack of use. I do miss it a little bit as it was occasionally very useful.
I don't want to spend much as I won't use it much but also don't want a wasteful throwaway either.
Screwfix have a couple of cheaper options. Any thoughts on these or any other suggestions around the £50 mark?
https://www.screwfix.com/p/makita-m4301-450w-electric-jigsaw-240v/5324r£45 The base plate looks a little cheap and it doesn't have a speed selection wheel. It is a Makita but their red range which I think is their diy range. Edit: actually it's available elsewhere for £33.
https://www.screwfix.com/p/erbauer-ejs750-750w-electric-jigsaw-220-240v/874fx£60 looks like it has a better base and speed wheel. But it's erbauer, which is not Makita. But is it twice as good as the Makita?
Many thanks in advance of your help.
Or look for a second hand one. in my experience, there’s a huge difference between the low end and high end jigsaws; I’d take a used high end model over a new low end one. I’ve found the Bosch (blue) jigsaws to be very good.
I have a Bosch green one works fine and cuts straight!
Not comparable to a blue Bosch bit it works!
Cheers James
