WonderWoman":2v3pmat9 said:
Dont know if I said but my boss bought a scroll saw, I tried it and the wood caught on the blade and it went all crazy, Im not strong enough for a scroll saw(im such a wimp)I was surprised how much puff jigsawing took out of me!
:shock:
No, you never mentioned that before. I wish you had. I also wish you lived a bit closer to me so that I could show you how to use a scrollsaw properly. Scrollsaws can catch the wood and lift it from the bed, but that's usually because the operator isn't using the saw properly. It does take a little bit of practice to master a scrollsaw, with the emphasis on 'little bit'
. A novice will often find that blades break frequently or the wood catches on the blade and lifts off the table. Both can be disconcerting at first.
I'd suggest you try again with a scrollsaw and practice on some waste wood. It would probably be a good idea to use a fairly large (say, 25cm x 25cm) piece of 6mm plywood so that you've got something of substance to handle. When you feed the wood into the blade, try to just cut a straight line. You'll probably find this difficult to start with because scrollsaw blades have a tendency to track to the right of the line of cut. Just turn the wood very gently as you feed it in so that the cut gradually veers back to your line. Don't turn the wood suddenly or it'll be obvious where you've gone off-line.
In fact, it's turning the wood suddenly that often makes wood catch on a scrollsaw blade and get lifted off the table. This is because you can't make a turn on a scrollsaw unless you are feeding the wood forward at the same time. Although that might sound difficult to do, it isn't and many scrollers can make apparent 90 degree turns quite easily after a short while.
I'd be interested to hear what sort of scrollsaw you used. Some of the cheaper models can vibrate a lot, which makes it much more difficult to control the wood and increase the liklihood of a novice catching it on the blade.
I was
astonished to hear you say that you needed strength to use a scrollsaw - something's wrong here!!! Most of the work I do uses the lightest of touches and I often find myself just using my thumbs to feed in the wood. Perhaps your blade was blunt and needed to be replaced? Thinking about it, you'd be more likely to catch your work on a blunt one than a sharp one, too.
Gill
