Jig day
pjwillms
10 Dec 2024
Rct
I looking for advice how to fix the log to a bandsaw jig as I am new to wood working any advice will be appreciated.
I have had a quick look a lot of them screw through the plywood in to the log wood that be ok.ty for your reply
Be cateful here as if you try and take a slice not near the centre then the force is unsupported and it relies on your screws "holding".
Could you recommend a way of fixing the log and thanks for your reply very helpful ty
+1 for getting a flat surface first
My preferred way is short rag bolts through the upright ply into the log, take a cut to flatten one side then turn it 90° onto the flat surface and refix.
Taking a bit of time to work out the best orientation to cut the log is always worthwhile
Tris has had a bit of a phonetic breakdown lol.
To clarify they are lag not rag bolts, American name and it’s a misnomer as they have a screw thread not a bolt thread, in this country they are more commonly known as Coach screws - they have a hex head, different again from Coach bolts which have a domed head with a short square shaft underneath which is hammered into timber preventing the bolt from turning.
Ian
