That fine Mr Charlesworth helpfully suggests
(a) once you've decided on the correct height for the rest, cut a block of mdf etc as a wheel/rest spacer, so the rest can always be repositioned at same height above wheel.
(b) forget the rest leg-screw adjuster, set grinding angle by adjusting amount blade projects from guide, and
(c) lock and NEVER move the rest between wheel true-ings for rest won't go back exactly the same, no matter how carefully you try!
In short moving the rest will require subsequent use of the diamond device if you expect 90 deg accuracy. None of this is a problem for carvers etc for whom the grinder is really designed. Applies to all Tormek style wet grinders.
