Walney Col
powertools":1nsyqnfh said:I don't normally get involved in this type of thread anymore but your solution to this problem is simple.
I've already done everything you suggested apart from filing out the mounting holes and the maths are telling me that wouldn't be enough to fix it. If there's 1mm side to side movement over the 18mm vertical blade travel it means that the top and bottom mounting holes over a 127mm long blade are in the region of 7mm out of alignment horizontally. And with the best will in the world there's no way you could file 3.5mm+ out of opposing sides of the 2 mounting holes, the clamps simply don't have that much meat in them.
In any case if, I bought it to use, not to fix.
Col.
