Saer Llongau":1ed1goz9 said:
D_W":1ed1goz9 said:
koyama-ichi are probably the lowest price "good" chisels, because their finish level is relatively minimal. They are appropriately hard, too.
I wouldn't call them appropriately hard, at least not compared to my Kikuhiromaru's. My chisels are almost full hardness, at least 65 on the Rockwell scale (I did ask them to make the chisels that hard).
None of the blacksmiths make chisels that hard anymore.
Btw, they sharpen just fine on my Shiro Suita with lots of renge.
Maybe they vary. I had a set of them at one point that were definitely full hardness. As were the older Ouchi chisels. I think they're all a little bit more practical if they're down a click or two, and the state of most vintage tools that I find would agree. The hardest vintage japanese irons and chisels that I've found have gone mostly unused because at 65 or above, they present a technical problem. they don't sharpen well on natural stones (and if your chisels sharpen well and in a reasonable time on a suita, and easily - not just the soft backer, but the steel itself, they're probably not 65 hardness), and they will have strange failures if sharpened on harsher synthetics.
The hardest chisel that I have requires such care in sharpening and use that technically, it can last a long time in use, but in practice, it can be a bit of a nuisance (that is a kiyotada parer - chisels don't come harder, and if it didn't have value due to being kiyotada, I'd temper it).
When you factor in the odd failure that happens here or there in the 65 hardness chisels, something two clicks back from there is more practical in the end. You can hone that something faster and chipout is much less common because white steel is much tougher at 62-63 than it is at 65.
I know that there are legendary tales about blacksmiths in japan, but none of the chisels are really anything better than just a bit better than the better english stuff. Beyond that, there are trade offs. Certainly, the Japanese have managed to keep making very clean blade steels, but even the very best were returned to blacksmiths all the time by professional users (especially temple makers who complain about anything that can't be used all day without sharpening, but that will also not tolerate some levering. That caused a lot of the better tokyo makers to quit catering to them - they wanted the impossible).
At any rate, in the interest of actually getting work done with my chisels (which includes mortising planes), I sold my ouchis (which were the older harder ouchis) and kept some mokume iyoroi chisels that sharpen really well on a washita. It's a better system (and faster) than trying to live at the edge of everything.
FWIW, I have about $15,000-$20,000 worth of natural stones right now (i sell them), so there aren't a lot of things that I haven't tried. I just can't argue with a chisel that can chop a plane mortise and be corrected in 15 strokes on a washita, and then chop another one. The ouchis would lose a corner here or there, they just weren't up to it. I can't say the same would be true for cheaper iyorois, I don't have any (the mokume chisels are overpriced for what they are - which is generally true across all lines - the pattern steel and stuff is hocum, but I found mine half price). For the ouchis, I paid the princely sum of $450 for 12 of them due to nobody having a clue about what they were at an auction called "MJD" here in the states. Nice chisels, but better for some dude who only chops dovetails in soft woods.
