edmund
Hi Everyone,
I thought I'd see if someone could come up with some helpful suggestions for the following problem I'm having with an old Record 5 1/2 jack plane. When I'm using a square edged iron, in order to get the cutting edge parallel with the sole of the plane I have to use a fair amount of lateral adjustment. This ends up with the cutting edge at one side being quite close to the front edge of the mouth such that the shavings jam the gap quite quickly. I've tried moved the frog back but it doesn't make any difference. I've also moved the chip breaker back to allow more visible cutting edge. Something in the set up is obviously not square but I can't readily identify what. So, what's the best way to solve the problem? Should I just offset the frog to compensate?
Thanks, E
Thanks, E
