I think if I was hand dimensioning, rough-sawn timber, as I used to HAVE to do, I would listen to Jacob.
I'd rather square off four, three-foot lengths separately, than one twelve foot piece. In Rob's case, if you want to decide first, how to utilise the grain, then keeping the planks as a whole is helpful; but handling 12 foot planks - even over my 12" Sedgwick - can be awkward, and without help, doesn't always result in a flat 'lump of wood'!
Six feet is about the most I can manage in my shop anyway, unless I roll the planer nearer the open door. This is something I do only rarely, because of the neighbours. I've had no complaints thus far, so maybe that's why. I don't plane full width either if I don't have to. The noise levels increase as does wear on the cutters. This enables me to use a set of cutters for much longer between re-grinds, as I can move the fence and use different areas of the block, spreading the wear. I'm sure I'm not the only one who does this?
As for ripping, I observe the same rules as for the planer. Working alone in small shop, it's safer to cut all pieces to length first, which I do by hand, or across trestles, in the yard, with a circular saw. Again, mauling twelve foot planks over a table or bandsaw, is no fun on your own. So I fall on Jacob's side of the fence here, with the proviso that it depends on the job.
HTH :wink:
