Yes, and the method I describe is one way to do it.Yes. But I'm talking about migrating to Photos !
I think it was the 256GB version of this:Will check...!
I used to have a similar aged MBP. In all honesty, it doesn't matter too much which SSD you go for, but I'd look out for a Crucial MX500 which are well priced and good enough. Battery-wise, please get one from a reputable company. I bought one from Ebay. It wasn't the cheapest, but it was still junk (lasting only about 3 months before it would lose capacity in a matter of less than a hour doing very light workloads).I'm using a mid-2009 MBP (5,4) with 8GB or RAM. Which SSD did you use for your MBP and which battery are you going to use?
iPhots does not operate on the latest IOS as its 32bit and Catalina is 64bit, so iPhotos will not open.Yes, and the method I describe is one way to do it.
And your albums ? Your titles ? Keywords ? Your modified photos? There's an awful lot more to an iPhotoLibrary than meets the eye.Yes, and the method I describe is one way to do it.
In that case you may want to investigate the ways Photos can manually import libraries from other applications, including iPhoto and Aperture. Thinking back, when I last replaced my laptop the transition from the previous to the new photo app went unnoticed because the process was automatic and part of the overall process of transferring all my data from the previous machine. Obviously, if you’re transferring an old library from another machine you’ll have to arrange some sort of connection, either over a network, or a Time Machine or other backup on an external drive, or an iCloud account if you are sure you have enough storage space (if you don’t have enough storage on your iCloud a/c you can prevent Photos from trying to use it in the Preferences pane).And your albums ? Your titles ? Keywords ? Your modified photos? There's an awful lot more to an iPhotoLibrary than meets the eye.
Yes, I’m aware of that. Hence this thread.iPhots does not operate on the latest IOS as its 32bit and Catalina is 64bit, do iPhotos will not open.
Ah I see why you wrote that now, having re-read my first response in post #6. In the last sentence I inadvertently wrote “iPhoto” instead of “Photos”. But in any case, since you also want to migrate all the additional info (keywords etc) rather than just the images alone, maybe my second suggestion in post #27 is more useful.Yes. But I'm talking about migrating to Photos !
But a lot of the SW that runs on it is.I don't quite follow you...Catalina isn't subscription based.
