katellwood":3jtyud33 said:
If the blade is not parallel to the slot it will still always (well nearly always) cut square
That's not exactly correct. If the slot and blade are not parallel then as the work is advanced, it will be travelling across the plane of the blade. As the work is advanced the cut face will be driven into the saw plate. If the work is clamped to the mitre gauge fence, it will cause the saw plate to deflect. If it isn't clamped securely, the plate will cause the work to shift and the cut will drift away from the line. And, yes, when the work gets to the back of the blade, it will be caught by the bases of the rising teeth. At best this will create a poor surface finish in the cut. At worst, it could lift the work and send it back in your direction.
It might be easier to understand if you picture the angle between slot and blade as some larger angle. Suppose 10°.
