Hi Paul,
its looking quite different now but still not yet mature - I'm letting it evolve a little organically now.
I've started using the space more now, for both woodworking and exercising, which is so far working pretty well, but there are a few things that need addressing. Here are some pictures:
I have an MFT table, which I quite like, but I tend to use my rail square 90% of the time as I often seem to be cutting plywood, probably because I've been making benches lately.
Everything is on wheels which is defo. the way to go, especically for my setup because my two benches are the infeed and outfeed for my mitre saw, and also double up as track saw cutting stations or assembly tables or one large assembly table.
I am thinking of having another of those wheeled tables but priority right now is getting things off the floor - the reason being because that is getting in the way of me being able to wheel things around and clean up or reconfigure the space when I use it. So next priority is shelves or something, maybe racks for wood; the wood is starting to build up a little and its getting in the way.
Clamp storage is also a priority, currently they are attached to my MFT bench:
Wood is hanging around under my woodworking bench:
but also on the floor now, so that needs sorting out.
My latest project is a cutting board:
I'm going to put some curved inlays in it (is that the right word?) - the little piece of wood in the picture is a bit of a prototype
I've also put french cleats on the wall now, which I like a lot. I illuminated them from behind thinking it would look cool but it didn't really throw off enough light, so a bit of a failed experiment, but I'm glad I tried it:
Martin
