I have a problem with mould growing on the inside shed roof. Weirdly, it isn't all over, and is only growing in two spots; the opposite corners of the roof. The pic attachment shows the worst of the mould and the area it covers. The other mould spot is fist-sized growth and isn't growing.
The roof is fibreglass on 18mm OSB, then a 25mm gap for airflow, then Kingspan 75mm insulation panels, and finally, plywood as can be seen in the pic.
The shed walls are single skin breeze block and ventilation is via two small windows above a larger window. Unless I leave the door open, that's the only ventilation the shed gets.
In January I'll be buying a Dehumidifier (Desiccant) and in spring I'll be insulating the walls (as mentioned earlier in this post).
For heating, I have a calor gas fire and the temperature in the shed is always between 9 degrees and 14 degrees (I'd say it levels out at around 12 degrees).
Is there anything else I can do to combat the mould? It's starting to worry me.
