Some bloak
Hello everyone
I'm just at the beginning stages of building a workshop in a stone outbuilding- my first proper workshop in fact. These old stone buildings have plenty of character but are incredibly cold to try and work in during winter. Anyway, my first major task is to internally insulate the whole thing, walls, roof, floor, door and windows. I've read about so many methods of insulation I'm fairly set on what materials I intend to use and what my budget allows.
What I intend to do is to cover the walls and floor in a 3 x 2 stud frame/ batten and then insulate the whole lot with 50mm Celotex before top cladding everything in OSB and 22mm chipboard for the floor. However, Is it better to go over the top of all the battening with the Celotex boards, tape the joints etc. or cut the boards to wedge fit inside the 600mm centres?. Without getting into mass thicknessing, 50mm insulation doesn't match up with the 3 x 2 thickness anyway.
I tend to think the better way would be to cover the stud work and try to completely isolate the cold walls rather than wedge insulation between which would surely create thermal bridging all over the place by having the 3 x 2's exposed. I would probably also use a DPM sheet up the walls as well as the floor just to keep any moisture in the walls back as much as possible.
If anyone's got any opinions or ideas I'd be very happy to hear any as there's alot of work in doing all this and I'm keen to get it right. Many thanks for anything that comes back from anyone, much appreciated.
