dickm":2hzs2ot0 said:Probably doesn't need saying, but just in case :? :-
Don't try to sand a light wood inlay in darker wood ground; you'll just transfer dark dust into the light.
DAMHIK.
Gill":ix3jvbjb said:Apply sanding sealer before you sand/scrape/plane. It's standard procedure amongst marquetarians to protect contamination by wood dust of a contrasting colour.
Gill
stupid question but which wood do I apply the sealer to? Could you give me the step by step process as can't work out how what I should be sanding / sealing in what order ?Gill":30bi6tuq said:Apply sanding sealer before you sand/scrape/plane. It's standard procedure amongst marquetarians to protect contamination by wood dust of a contrasting colour.
Gill
Erhm. Its called sealer because it seals the wood pores. The sanding part denoted that after drying is easy to sand. There are many substances to seal wood. Others are: shellac, urea glue, CA glue, Epoxy, PVA glue, hide/bone glue.George_N":23r3tsth said:is that why it's called sanding sealer?
