A
Anonymous
Guest
After reading a few previous threads on injuries, I started to wonder what constitutes as an injury.
As a pro wood worker I have suffered a few "injuries" over the years but do not class them as injuries in my mind, maybe cuts at most. I have probably had 20 stitches in 4 cuts in the last 10 years, all inflicted with sharp chisels, I have also cut myself where I knew it required stitches but couldn't face a four hour wait in a&e, so didn't go and took my chances. I have never had a day off due to injury.
So heres my definition of injury,
A BAD CUT; there are 2 very distinct body parts, totally seperate, or if still attached the little bit is extremely wobbly.
A FALL; minimum height of at least 3ft, body needs to attain a perfect horizontal position, with all parts of the body of the ground at the same time, with a forward speed of 10mph+, also carrying 2cu timber.
A SPLINTER; minimum size, 15mm, strategically placed under the nail.
BRUISING; Does not count, unless accompanied by broken bones.
BROKEN BONES; do not count, if minor ones, i.e. fingers and toes.
etc
etc
