TheTiddles":2em5yx6r said:Are you going to keep tissues in it?
Aidan
Probably, maybe, Chris :duno: The problem is that RI gives scant instruction in the article in F&C on just how to go about doing this sort of thing and as it's the first time I've done this type of project I did give an awful lot of thought into the best way to do it. I read the piece very carefully and adopted much of his methodology, but a lot of it is 'by guess and by God'. Hopefully it'll turn out looking not too shabby...whether or not it's the way that RI would have done it remains to be seen. Today I've cut the thing in half (not through the bandsawMr T":2485z1ak said:Hi Rob
I haven't really thought this through properly, but would it have been possible to have veneered the sides with the elm burr then route grooves into it to take the ebony strips.
Chris
No lock, just a knob or handle of some sort - RobIan":23rm2s6i said:Will you be making the lock yourself?
Ian
mtr1":23dq67sa said:Overall its a lovely box, I'm not keen on the plainness of the feet, and I think it could benefit from a pull out tray.
I think you over complicated the build, but I guess how you build it is up to you and your time. Nonetheless a very well made box, and very attractive.
Sorry Mark, misunderstanding. Yep, there are what I would term 'lift-out' trays in the pic posted above...I thought you meant pull out drawersmtr1":1tn99aq7 said:There seems to be two pull out trays in the original Rob?
That's an easily doable possibility Paul, but I wanted to get the authentic Inghamish look which is why I went for brass. They're only screwed on, so could be replaced if I get fed up with the brass look. I did think about getting some round feet from CHT but I thought that thin bits of 3mm brass would look better. I also um'd and err'd about placing them flush, but went for the 3mm overhang...again in keeping with the RI theme - RobPaul Chapman":1419g1fk said:A lovely job, Rob =D>
I think I would have gone for Ebony feet.
Cheers :wink:
Paul
