Ttrees
Iroko loco!
Hello folks
I managed to snap one of the threaded rods that connects the motor assembly together.
One of them was very bent, and was causing issues with assembly.
Looking at the inside of the fan shroud, you might be able to see where the fan was making contact with it.
I was thinking of replacing the threaded rods with stainless steel ones, to enable me to have this shroud sitting further away to avoid rubbing with the plastic fan,
and also the fact that these four rods are taking the full weight of the motor.
Checking with a magnet, these rods are of normal steel with a "smooth section" for lack of a better word, and is a regular thread.
Why does these threaded rods have a smooth section?
Can I just ignore this, and replace them with stronger regular stainless threadbar with no smooth section.
I see no good reason for this, as nothing will be in contact with them.
I was thinking of getting stainless nuts while I'm at it.
Thanks again
Thanks again
