got wood
Hi all...
Just purchased the above from rutlands, and have a few queries if anybody has this mitre guage.
Firstly, it came out of the box quite dirty, and not as 'sparkly' as I had hoped (rust started to form on some bolt heads, and underneath the slide) - I can only assume this is an old item (been around a few years now i think?).
This doesn't bother me too much, but am considering sending it back.
My other query is this. Should the fence sit exactly 90 degress to the table, as this one doesn't. Without pictures, I shall try to explain (will post pic tomorrow if this helps). When i put a square on the table, and slide it to the fence, there is a small gap (maybe .7mm) at the top ie the fence is leaning back slightly. I appreciate this isn't a lot, but I would have thought that it should be square on a £130 precision bit of kit!!
Hope someone can help, and thanks in advance
Jamie.
Jamie.
