1"Krysstel":3rjpbzzq said:More pictures, as requested.
I'll be ordering a couple of Tuffsaw blades on Monday.
I want to try and see if it's possible to resaw at least up to about 120-130mm. Anyone have any idea what maximim blade width the saw can cope with ?
Yes It's standard as you can see here.Krysstel":3rjpbzzq said:
Why is the switch on the rear, away from the operator ? Is that normal ?
It looks as if the adjustment screws have been changed from the original grub screws.Krysstel":3rjpbzzq said:
Top bearing blocks need a clean up and adjustment.
Same story with the bottom bearings.
Please let me know if you get a positive answer I can use a set of thrust bearings.Krysstel":3uf76ox9 said:Our friend Google led me to a Yahoo group for Inca machines and an old post there has led me to this place in the US http://www.spaceageceramicguideblocks.com/. Apparantly they can (at least they could a year ago) supply ceramic guide blocks and thrust bearings as direct replacements for the original Inca blocks. They're supposed to last forever without wear :shock: I've fired off an e-mail inquiry and we'll see what happens.
Here's a couple of pictures that prove such blocks and guides exist :wink:
Mark
Mine does say 'Inca' on it but the full name of the machine is the Euro 260 and it was made in France...no relation to Kity though as far as I'm aware - RobKrysstel":2lcxabek said:Was the Euro260 perhaps French made ? Some relation to Kity perhaps ? - just my speculation.
Mark
Krysstel":syjhyrdr said:Jerome -
Really ? 1" blade ? I thought I'd be pushing it if I tried a 3/4" :shock:
I'll post back if I hear anything from them regarding ceramic blocks & guides.
Mark
Here's an excerpt from the first issue of Fine Woodworking:
The Inca tools are made by Injecta, a 55 year old
company with a thousand employees, specializing mostly in
precision aluminum die castings. The woodworking tools
represent about 25% of its business. They got into the
business some 35 years ago when a customer ordered molds
for a saw and then could not pay for them.
The pictures would help. Tracking is done while the blade is tensioned and running. The tracking adjustment is behind and below the tensioning adjustment screw. It has a locking knob you need to slack off first. With mine I can get the blade to track anywhere on the tire. The upper guide blocks do move with the upper guard but once tightened are steady. I have a set of pics I'll put up on my website so you can see how it should look when new(30years after :lol: ). I do look after my toolsmoerman":gq6x9ske said:I have bought a Flott 260 two month ago. It is an Inca 260 with a Flott label. It works OK but for resawingit wanders to much. I have a tuff saws 5/8" 3 tpi m42 blade. Also when I put maximum tension on this blade it wanders towards the fence. I took the guidepost from the saw for inspection and noticed two problems:
- the assembly which holds the guide blocks can move slightly sideways. There is no way of adjusting to minimize this play.
- The guidepost is fastened by turning a big screw against it. But the tension of the screw twists the guide post sideways which causes the saw to wander. Reason is that the guide is pressed against a metal plate which is secured at one side only. The force of tightening the screw presses this plate out of alignement.
Are there any hints how to improve these problems? If needed I can post some pictures to clarify my description.
Wout Moerman
