Somebody has asked about a rack for storing planes on Lumberjacks, and having set myself up for burning at the stake there thought why not get the mob out with scythes and torches here too!!!
Why not drill a neatly deburred hole at the rear of the sole of each plane, and hang them up by it using a pin screwed into a flat board at a slight upwards angle so they can't slip off? Use a round headed brass pin if you want to get fancy and prevent any possibility of scratching. Steepen the pin angle or put a bend in it if you happen to live in an earthquake zone! ;-)
A fancy rack (a) smacks of gratuitous joinery, (b) unless very carefully designed risks being awkward to use/having the planes fall out, and (c) will probably very quickly be outgrown as your collection expands in unexpected directions anyway.
Trying to decide if i dare attack my Veritas planes.
Fire away.....
ian
Fire away.....
ian
