NickDReed
Hi all,
Anyone know a good place to purchase imperial drill bits?
Specifically 1/2 inch?
Nick
Nick
There are projects that use both wood and metal that might be primarily metal.It's unlikely he'll use a lip and spur for metalwork.
He did post the question in "general metalworking"There are projects that use both wood and metal that might be primarily metal.
Nothings imposible with the current bunch of clowns at the top! They need more than a good beating because there is no reason to remove any legal requirement that would allow people to sell in any unit of measurement they fancy, we are now metric and used to what we have, seeing pounds and ounces would be a backward move.That was the stupidity that you are intimating is going to happen - which is simply untrue!
I'm sure that Steven Thorburn would disagree!there is no reason to remove any legal requirement that would allow people to sell in any unit of measurement they fancy
Oooops! - auto-pilot onThoburn.
The government may well merit some chastisement but it ought to be on matters of consequence. The issue of Metric / Imperial measures is not one of them and using irrelevant argument devalues and masks the real issues.Nothings imposible with the current bunch of clowns at the top! They need more than a good beating
Darn it!! I had looked out the 1000 8X1" slotted wood screws I kept in the loft. Thought I could sell them on Gumtree.The 'proposal' isn't - and never was - to 'Return to Imperial measure',
12.7mm seems to be a common enough size
