RogerS
Very good point, Olly. I've used the Trend Mitre Gauge (the one that bisects the angle) in the past and that does speed things up.
OPJ":mdxe9yc9 said:I sometimes wish my saw had a laser line, as I reckon it would make life a bit easier when trying to set the saw for an angled cut that isn't given by one of the preset stops. Otherwise, you've got to try and 'roll' the blade along the wood until it's parallel to the line and keeping making test cuts, which always takes time.
big soft moose":xk33tlfo said:OPJ":xk33tlfo said:I sometimes wish my saw had a laser line, as I reckon it would make life a bit easier when trying to set the saw for an angled cut that isn't given by one of the preset stops. Otherwise, you've got to try and 'roll' the blade along the wood until it's parallel to the line and keeping making test cuts, which always takes time.
I just use the wixey angle finder box thingy for that - as far as lasers generally go my experience is that they are worth having on the higher end kit but on cheap kit (like the rexon we had at work until i upgraded it) they are so inaccurate as to be neither use nor ornament
RogerS":3ss62mih said:So, as the first saw wasn't collected, I re-opened it to have a look to see what it was like. Not as bad but still very graunchy. Horrible to use.
So what's next? I do have a third saw coming from Screwfix (thanks for that, Moose). Hasn't got a laser but maybe I can live without that. It's supposed to be here by now. Just have to wait. Third time lucky?
RogerS":1ju41oge said:No, third time not lucky.
Having waited in for my pre-noon delivery from ScrewUp, they tell me that they have not even sent the order :twisted: . Clearly telephones don't exist in Forum etiquette stops me from using more appropriate words but I have a job for ScrewUp that involves Sex and Travel.
RogerS":329awdpx said:That's kind of you, Moose. I do have an SCMS but it doesn't trench and I need to make a load of tenons..and yes, I know that I can make them in other ways...etc etc....and to be honest, given all the time I've wasted in trying to get this sorted, I could have gnawed my way though them.
But sometimes a boy needs a new toy.
I'm OK with 110v, by the way. But equally critical is that I have an existing infeed/outfeed arrangement and so I have to check the saws dimensions to see that I don't have to rebuild the workshop.
RogerS":2vkpwjob said:I'd not really considered a RAS as I still need the mitreing capability of the SCMS. And they scare me. :shock:
RogerS":2q3lpndy said:You've seen my place. A swung cat would have a very bruised head!
