sploo
Somewhat extinguished member
So, genius here decided to install an integrated Bosch dishwasher into an IKEA kitchen; forgetting that the shorter kickboard height + longer door height of the IKEA system means that you can't put an IKEA door on a third party dishwasher - at least, not if you plan on opening the door more than about 45 degrees
There are commercial solutions, but they mostly seem to involve a sliding mechanism that causes the door to ride up as you open the dishwasher. I'm not keen on it, plus there's an island opposite the dishwasher, and having the IKEA door extending further than the dishwasher door seemed like a bad idea.
Cue a few months living with a prototype hinged door, which (having held up well) has now been replaced with a finished version.
I ripped a full sized door in two, then "harvested" the oak frame strips from a spare door; such that I had the original door in two sections, each with a full frame. The sections are joined using some hinges (not recessed, as that forms the required gap between the panels), and some suitably positionedneodiddlyum... neodiddy... ne... strong magnets:
When installed, the magnets hold the two panels flush:
Once the door is tipped, the bottom section hits the recessed front of the dishwasher, and the panel swings on the hinges:
Lifted back up, and the door snaps back flush:
The hinges are just visible in the right light, so I guess a matt finish would be preferable, but I went for stainless, given the high moisture/steam content in a kitchen.
