One more attempt at persuasion I'll try, as I don't wish to "bully" anyone,
but getting strong vibes of
this is all way too complicated to even bother with,
rather than outright that won't fly for my situation, for whatever reason, I can't think of TBH.
Perhaps there's a bit of a sting to paying more for a little box of clever electronics,
than the machine,
If so, then I urge you to look at the cost of one of these Italian beauties, just for perspective.
Though the knowledge of being
easily able to power something simple
like your bandsaw (it's only got the one motor) is kinda like the Mastercard advert.
I tried finding a good article that I've read before, which explains this very simply,
as I believe it's against the rules to give a link to the "rival" UK forum,
(that's where Bob resides, and the freely available induction motor document will be under his signature)
Unfortunately google images only comes up with super complicated stuff, and I can't find something simple like on the article mentioned.
Let's see what your motor will likely look like perhaps...
Pop off the lid, and you'll see six terminals and an earth or ground.
Note the three brass "straps"
If you see them like so, then the motor is ready to rock.
(configured to low voltage
Delta, 240v that is.)
If it looked like there were only two brass straps, then those will be orientated
across instead, with the third strap stacked on top of another, which is for 400v.
You can't really do this wrong on these motors.
Now you've seen the Delta low voltage configuration, let's learn some parameters.
This motor should look fimiliar, I believe some lucky bar steward won it at auction for sixty odd quid, fair price for a motor I suppose...
Not to mention, that it came with an Italian bandsaw attached!
Jeepers look, it even gives instructions on how to configure it to Delta, well I'll be darned!
It's a 50hz motor, so suitable for most of the world, (apart from America, which needs 60hz motors)
that's a parameter.
We see it's got 1.1 Kw of oomph, or 1.5 horsepower,
that's a parameter.
We see "2" so we know it's a "two pole motor"
We would know it's a two pole motor anyway, as the speed is close to 3000 RPM,
actually 2790 in this case. (four pole motors run at half this speed, and have larger pulleys)
I digress...but
that's a parameter.
We can see beside the Delta illustration, that at 240v, it uses 3.9 amps,
that's a parameter.
So depending on what VFD, you get....some don't give the option of entering the amps,
and as said buying one rated for larger motors, it's necessary to know that parameter is available with a known unit, to give the motor what amperage suits.
They constantly have new ones coming out all the time.
That stuff above is about six parameters to enter.
It might look more like this in the booklet when you jog it down on the back of the cover
Max Frequency, 50hz
Min Frequency, 50hz
Some other Frequency parameter may be required, which will again be 50hz
Motor power, 1.1Kw
Amps 3.9
Motor pole number, 2
Voltage, 240
And the rest is easy peasy...
Factory default, yes, (this is the first thing to do)
Reverse rotation disabled, yes.
Ramp up time/Acceleration, I believe I've my saw set to go to full speed in seven seconds, i.e 7.
Coasting stop time/Deceleration, I believe I have that set to around the same. 7.
Push buttons enabled, yes.
That's 12 parameters right there, the likes of whats required on the more complicated
"huanyang"
I mention that as it's capable to de-rate motor power, so you could upgrade the motor
down the road if you felt like it needed more oomph.
I will say however that the in-built cooling fan runs all the time and is annoying.
I installed that one on the tablesaw, since I generally don't use the machine for odd wee cuts,
like I do with the bandsaw.
That should do it for ya, have a read on Bob's induction motor document,
as you don't want to enter those parameters wrong into the thing.
It'll explain why, as most of these things above are related to motor RPM, so a wrong command
might let the magic smoke out.
There's helpful folk here all day long to help at any stage,
run your parameters by us, and whatever else,
Hope that helps
Cheerio
Tom
