Identifing a type of rule by J Rabone and Sons
PhotoMan Mark
7 Dec 2024
Manitoba, Canada
    533.9 KB
    518.6 KB
    494.5 KB
    502 KB
    594.6 KB
    427.1 KB
Its a standard carpenters folding rule. I have my dad's old one plus another. Nither are Rabone however. Back in the day every carpenter would have had one and overalls even had a leg pocket to carry them. Mine dont have the edges marked but there were various formats. Three feet was the common version but shorter two foot ones were around as well. That one looks very well used. See how worn it is at the hinge. That would have been in and out the pocket thousands of times.
John
The main scale seems to be in 10ths so maybe it was for a particular trade, the edges look to be in quarters which is handy because 10 doesn't divide by 4🤔.
It appears to be a less frequently seen model.
4 fold 1000mm with normal inches on the edge.
Not got or seen one before.
Cheers, Andy
Tenths of a foot are, I think, engineer's measures. I've got multiple tape measures in tenths; likely used when scaling off drawings.
John
Hi John , I dissagree, its says on it John Rabone & sons, I just didn't add the photo.
Well, for the Squarish aficionados, even rafter squares in earlier days were marked on different scales, in 16ths' 12th's 10'ths (and no, I am not talking about shrink rules or engineers rules- just basic carpenters rules))
Rafter squares of early vintage oft have a chicken-scratch scale in the corner with 1/100Th inch divisions
WTF you may well ask, but some of the "How to use a square" tomes relate how to use a square as a calculator
Here's a link to one.
https://www.abebooks.com/servlet/Bo...tn=steel+square&cm_sp=snippet-_-srp0-_-title1
but it was eventually expanded into two volumes.
And had quite a bit more info than I could absorb or put to use!
I think Townsend also had a book about steel square
As an aside. Fred T Hodgson (a CDN architect) also published a large number of books circa +/- 1900 on a variety of subjects of woodbutcher/yarchitecture/deisgn
