Ttrees
Iroko loco!
Hello all
After just recovering from another bout of TAS (tool acquisition syndrome)
I'm faced with another dilemma :roll:
How to tell the difference easily and speedily, between this pair of Stanley 5 1/2's.
I can look closely and tell by a few things...namely the slightly shorter blade, a bit of tarnishing on the lever cap,
a small camber on the old one for jack work, while the newer one is to be used as a smoother,
with barely any camber atall.
These two, are nearly my only used planes now ...apart from a 70's maroon occasional staple and concrete hitter...
I'm hoping some of you folks have figured a solution that I like ...
I just can't think of a method of differentiating one from the other from a few angles that's not hideous.
I'm not going to be making use of an allocated spot in a cabinet, as I like having the two out.
What have ye done?
Obligatory piccy in hope of an elegant solution
Tom
What have ye done?
Tom
