hawkeyefxr
I have got back into making Solitaire boards. Previously i have mounted them on a sheet of 10mm ply and clamped it to the router table with a centre point so the board rotates, the problem is that this restricts the cut vertical movement which means i have to take two bites at machining a round.
What i have thought of doing is using a short length of 6mm*20mm bar, the router table will be machined to accept the so it slide giving me adjustment to use different diameter boards. A 6mm dia bar threaded at the end so that it screws into the square bar from the underside. The problem is this could weaken my router table top.
My router table is home made and i have had it for many years and for me is perfect (except for the radius cut lol) It's thickness is 1 1/4".
This is in my head so have no drawings .
Has anyone done something like this, anyone have a better idea, any ideas really
