mr edd
Hi all
I acquired some I Sorby English mortise chisels with a Mr punch stamp above the name stamp, 1/4'', 3/8'' and 1/2'' all in poor condition, heavily rusted and lacking handles and resolved to try to get them to working condition again.
I de-rusted them, made some new handles using ash from a tree I acquired from a field near Saffron Walden which I have been painfully processing from riven hunks by hand to quarter sawn boards story for another day.........
However the back/face whatever you want to call the bit of the chisel on the opposing side to the bevel was badly pitted so started to try and remove some of the pitting on bench stones, then sand paper, and then in a moment total impatience I picked up a mill file started to draw file the back of the chisel to try and remove the very deep pitting.
I was expecting the file skid over the metal and not cut but to my surprise the file worked quickly and I managed to remove all of the pits and following a few minutes of work of the diamond stones I had a flat smooth chisel back with edges and an intact cross section.
ps my filing is not normally that accurate.
So question,
Is the steel normally that soft?
I did some trials in redwood, walnut and d fir and the edge did not seem to suffer.
Probably more an academic question than practical as for mortising uber sharp is not the be all, but just interested to see how others experience compares.
pss my grinder is buried under a mountain of tools atm so I used the file to re-establish the totally buggered primary bevel of the chisels as well before going to 300/1000etc.
The file much quicker than the water stone grinder
Evening all
Edd
So question,
Evening all
Edd
