BearTricks
I have a 12" square piece, about an inch and a half thick, made from three pieces of sapele laminated together and intended as a stool seat. What I need to do is cut an angle all the way round the piece as seen in the below image.
Is it as simple as just clamping the piece to a bit of mdf or ply, raising the board up to the right angle using wedges then running it along each edge? If it is then good, but I've spent a while hand planing this wood to be perfect and I don't want to run in to any issues, for example with excess pressure on the blade etc. A bandsaw is all I have access to at the moment. The table saw is away in storage since I don't have enough room for it.
