I need some advice before buying a whetstone grinder
gettingold
New member
23 Jan 2025
wales
I'm looking to buy a whetstone grinder to sharpen chisels / plane blades and maybe my lawnmower blade so I thought about buying a Clarke whetstone grinder but I didn't know what model was the best so I contacted machine mart and they didn't have a clue so I contacted clarke tooling and they said the only difference is the size of the wheel but isn't the motor less wattage on the more expensive machine.
Clarke CWS250.
Motor: 60W, 230V
3-position switch (Forwards, backwards, off)
Adjustable Wheel speed: 30-150rpm
Grinding Wheel: Ø250x50x12mm
Leather Honing Wheel: Ø200x50x12mm.
Clarke CWS200B.
Powerful 180W, 230V induction motor
200mm diameter grinding and leather honing wheels
Wheel dimensions (dia x Width x bore):
Grinding – 200dia x40 x12mmm
Leather honing – 200diax30x12.5mm
Did you phone Machine Mart customer services or tech? Big difference. The larger wheel has more momentum when up to speed and will need less power to keep it turning. Obviously. You let the tool do the work and not lean on it, or you will stall it.
I went on live chat. If I was to buy the machine would you recommend the 10" over the 8". I want a machine for occasional use so would you recommend this brand of machine or do you think I should get a different brand because there doesn't seem to be any reviews for the one with the bigger wheel.
I would heed my advice and buy a used tormek. I brought a new jet many years ago and tbf its a much better machine than those clarke ones but I still wish I'd brought a tormek even after so many years. If you buy a tormek you can always sell it on buy a Clarke and you can't give it away tormek are so much better.
Hi Gettingold -- me too !!! It depends on what you do in your workshop but consider the Robert Sorby Pro-Edge rather than a whetstone grinder.
A wet grinder does have its merits but I think they suit a situation where they are in very regular use, they are more messy and are limited in versatility.
I was going to buy one but ended up with the Pro Edge and find excellent as well as versatile, I also do metalwork and its useful for this as well as sharpening woodworking tools, chisels plane irons and turning chisels/gouges
Just my three penn'orth !
